					                		Trouble updating NEMO - Support                                    </title>
                <link>http://forum.genoqs.net/community/support/trouble-updating-nemo</link>
                <lastBuildDate>Thu, 13 Aug 2026 21:56:14 +0000</lastBuildDate>
                        <title>Trouble updating NEMO using Linux</title>
                        <link>http://forum.genoqs.net/community/support/trouble-updating-nemo#post-286</link>
                        <pubDate>Fri, 03 Nov 2023 12:44:58 +0000</pubDate>
                        <description><![CDATA[Hi Genoqs-Lovers,
I&#039;m searching for help, too, updating the nemo to 5.30.
I did the last update - to 5.00 - some years ago using linux / cutecom and it worked well.
Trying now to update t...]]></description>
                        <content:encoded><![CDATA[<p>Hi Genoqs-Lovers,</p>
<p>I'm searching for help, too, updating the nemo to 5.30.</p>
<p>I did the last update - to 5.00 - some years ago using linux / cutecom and it worked well.</p>
<p>Trying now to update to 5.30 using the little "manual" I wrote last time failed.</p>
<p>First sz didn't start for uploading the new .elf-file (cutecom 0.30 using MX Linux)  -&gt; I updated to cutecom 0.50 with the actual debian-distro and also installed lrzsz.</p>
<p>Now the transfer of the .elf-file starts with a upload window, but no progress is done - using the byte-counter shows no transfer.</p>
<p>Does anyone have experience with updating the Nemo under linux and could give me some hints. Any help is appreciated. No problem, if annother distro would help.</p>
<p>BTW: thank you for all the work to keep the nemo swimming...</p>
<p>Regards</p>
<p>Claus</p>]]></content:encoded>
                        <category domain="https://forum.genoqs.net/community/support">Support</category>                        <dc:creator>cphetzner</dc:creator>
                        <guid isPermaLink="true">http://forum.genoqs.net/community/support/trouble-updating-nemo#post-286</guid>
                        <title>RE: Trouble updating NEMO</title>
                        <link>http://forum.genoqs.net/community/support/trouble-updating-nemo#post-182</link>
                        <pubDate>Sun, 25 Apr 2021 09:55:42 +0000</pubDate>
                        <description><![CDATA[@wilson
Yes, thanks very much for all your help.]]></description>
                        <content:encoded><![CDATA[<p>@wilson</p>
<p>Yes, thanks very much for all your help.</p>]]></content:encoded>
                        <category domain="https://forum.genoqs.net/community/support">Support</category>                        <dc:creator>AndyCap</dc:creator>
                        <guid isPermaLink="true">http://forum.genoqs.net/community/support/trouble-updating-nemo#post-182</guid>
                        <link>http://forum.genoqs.net/community/support/trouble-updating-nemo#post-181</link>
                        <pubDate>Fri, 23 Apr 2021 09:12:03 +0000</pubDate>
                        <description><![CDATA[@andycap
Great Andy sounds like you are good to go 🍻]]></description>
                        <content:encoded><![CDATA[<p>@andycap</p>
<p>Great Andy sounds like you are good to go 🍻 </p>]]></content:encoded>
                        <category domain="https://forum.genoqs.net/community/support">Support</category>                        <dc:creator>handsfelloff</dc:creator>
                        <guid isPermaLink="true">http://forum.genoqs.net/community/support/trouble-updating-nemo#post-181</guid>
                        <link>http://forum.genoqs.net/community/support/trouble-updating-nemo#post-179</link>
                        <pubDate>Wed, 21 Apr 2021 06:26:58 +0000</pubDate>
                        <description><![CDATA[Hi Eric,
Thanks for the info.
The only reason to roll back is if there is some stuff missing in the transfer and after a while It goes bang!
I&#039;ll grab the file from cvs and test I can tra...]]></description>
                        <content:encoded><![CDATA[<p>Hi Eric,</p>
<p>Thanks for the info.</p>
<p>The only reason to roll back is if there is some stuff missing in the transfer and after a while It goes bang!</p>
<p>I'll grab the file from cvs and test I can transfer that.</p>
<p>Many thanks for all the help guys.</p>
<p>Cheers</p>
<p>Andy</p>]]></content:encoded>
                        <guid isPermaLink="true">http://forum.genoqs.net/community/support/trouble-updating-nemo#post-179</guid>
                        <link>http://forum.genoqs.net/community/support/trouble-updating-nemo#post-178</link>
                        <pubDate>Tue, 20 Apr 2021 22:45:26 +0000</pubDate>
                        <description><![CDATA[Hi,
We have copies of it if needed. It is also stored online if the original CVS (fork) repo.
v5 was primarily about doubling the grid size and fixing bugs. You probably won&#039;t want to roll ...]]></description>
                        <content:encoded><![CDATA[<p>Hi,</p>
<p>We have copies of it if needed. It is also stored online if the original CVS (fork) repo. https://sourceforge.net/projects/genoqs-fork/</p>
<p>v5 was primarily about doubling the grid size and fixing bugs. You probably won't want to roll back.</p>]]></content:encoded>
                        <category domain="https://forum.genoqs.net/community/support">Support</category>                        <dc:creator>Eric</dc:creator>
                        <guid isPermaLink="true">http://forum.genoqs.net/community/support/trouble-updating-nemo#post-178</guid>
                        <link>http://forum.genoqs.net/community/support/trouble-updating-nemo#post-177</link>
                        <pubDate>Tue, 20 Apr 2021 21:18:05 +0000</pubDate>
                        <description><![CDATA[Hi Wilson,
Running from the ram seems ok.
do you know any way of backing up the 1.62 version installed before flashing?
cheers
Andy]]></description>
                        <content:encoded><![CDATA[<p>Hi Wilson,</p>
<p>Running from the ram seems ok.</p>
<p>do you know any way of backing up the 1.62 version installed before flashing?</p>
<p>cheers</p>
                        <guid isPermaLink="true">http://forum.genoqs.net/community/support/trouble-updating-nemo#post-177</guid>
                        <link>http://forum.genoqs.net/community/support/trouble-updating-nemo#post-176</link>
                        <pubDate>Mon, 19 Apr 2021 08:29:04 +0000</pubDate>
Ooh, thanks for that. Will give it a go after work and get back to you.
Cheers
<p>Ooh, thanks for that. Will give it a go after work and get back to you.</p>
<p>Cheers</p>
                        <guid isPermaLink="true">http://forum.genoqs.net/community/support/trouble-updating-nemo#post-176</guid>
                        <link>http://forum.genoqs.net/community/support/trouble-updating-nemo#post-175</link>
                        <pubDate>Mon, 19 Apr 2021 08:23:38 +0000</pubDate>
                        <description><![CDATA[Hi Andy,
I am pretty sure from above output that the transfer was ok, rather this is just rather unhelpful feedback from the ymodem transfer (I always see the same thing)!
For piece of min...]]></description>
                        <content:encoded><![CDATA[<p>Hi Andy,</p>
<p>I am pretty sure from above output that the transfer was ok, rather this is just rather unhelpful feedback from the ymodem transfer (I always see the same thing)!</p>
<p>For piece of mind after the Nemo transfer to test/confirm this we can run the v5 code (without flashing) by entering the following command:</p>
<pre>go 0x00010040 <br /><br />If all goes well you can be confident to flash next transfer 👍  <br /><br />Wilson</pre>]]></content:encoded>
                        <guid isPermaLink="true">http://forum.genoqs.net/community/support/trouble-updating-nemo#post-175</guid>
                        <link>http://forum.genoqs.net/community/support/trouble-updating-nemo#post-168</link>
                        <pubDate>Sun, 18 Apr 2021 08:44:26 +0000</pubDate>
                        <description><![CDATA[Hi Guys,
I added a new post with this but thought I would add it here as well as it may notify people!
I am having troubles updating my Blue Nemo, the modem transfer always fails at exa...]]></description>
                        <content:encoded><![CDATA[<p>Hi Guys,</p>
<p>I added a new post with this but thought I would add it here as well as it may notify people!</p>
<p>I am having troubles updating my Blue Nemo, the modem transfer always fails at exactly the same place (294k), I have tried on a Mac Desktop, Ubuntu VM and a Mac laptop.</p>
<p>Sending: NEMO_OS_v500.elf <br />Ymodem sectors/kbytes sent: 2353/294kRetry 0: Cancelled<br />Transfer incomplete<br />Entry point: 0x00010040, address range: 0x00010000-0x000518b4<br />xyzModem - CRC mode, 1(SOH)/295(STX)/1(CAN) packets, 3 retries</p>
<p>I have used the mfill and dump commands to verify the ram is ok, no problem there.</p>
<p>Anyone any ideas?</p>
<p>Many thanks</p>
                        <guid isPermaLink="true">http://forum.genoqs.net/community/support/trouble-updating-nemo#post-168</guid>
                        <title>Trouble updating NEMO</title>
                        <link>http://forum.genoqs.net/community/support/trouble-updating-nemo#post-167</link>
                        <pubDate>Sun, 18 Apr 2021 08:41:43 +0000</pubDate>
Sending: N...]]></description>
<p>Many thanks</p>
                        <guid isPermaLink="true">http://forum.genoqs.net/community/support/trouble-updating-nemo#post-167</guid>
