					                		Phrase editor clarification - Support                                    </title>
                <link>http://forum.genoqs.net/community/support/phrase-editor-clarification</link>
                <lastBuildDate>Thu, 13 Aug 2026 20:43:57 +0000</lastBuildDate>
                        <title>RE: Phrase editor clarification</title>
                        <link>http://forum.genoqs.net/community/support/phrase-editor-clarification#post-90</link>
                        <pubDate>Thu, 02 Jul 2020 12:52:09 +0000</pubDate>
                        <description><![CDATA[Jean! Ignore this. I now realise that the chord need to be entered INSIDE the phrase editor, not in the step. Doh.. 😳]]></description>
                        <content:encoded><![CDATA[<p>Jean! Ignore this. I now realise that the chord need to be entered INSIDE the phrase editor, not in the step. Doh.. 😳 </p>]]></content:encoded>
                        <category domain="https://forum.genoqs.net/community/support">Support</category>                        <dc:creator>stratblue</dc:creator>
                        <guid isPermaLink="true">http://forum.genoqs.net/community/support/phrase-editor-clarification#post-90</guid>
                        <link>http://forum.genoqs.net/community/support/phrase-editor-clarification#post-89</link>
                        <pubDate>Thu, 02 Jul 2020 12:45:16 +0000</pubDate>
                        <description><![CDATA[Hey Jean. I tried this and, assuming I understood you, I had a 5 note Cm9 chord on a single step with all notes the same length, volume and STA value, I clicked into the step then into the p...]]></description>
                        <content:encoded><![CDATA[<p>Hey Jean.</p><p> </p><p>I tried this and, assuming I understood you, I had a 5 note Cm9 chord on a single step with all notes the same length, volume and STA value, I clicked into the step then into the phrase editor and the 7 polyphony lights around the right are illuminated. By choosing which one of the 4 phrase types I want in the VEL line I do indeed get a difference in the  phrase but the 'polyphony arc' of buttons does nothing to affect the 5 note phrase that I'm hearing. The phrase rhythm just goes 1+2+3 really simply through the phrase tones. The notes in the Cm9 will be C D Eb G Bb but I hear C G Bb G+1 octave F. I expected to dial in a polyphony value of 2 and just get 2 notes scooped out of the chord and then add in a random element with phrase types 3 and 4. I was messing about on phrase 'red 2' if that makes sense...Have I totally missed it?</p>]]></content:encoded>
                        <guid isPermaLink="true">http://forum.genoqs.net/community/support/phrase-editor-clarification#post-89</guid>
                        <link>http://forum.genoqs.net/community/support/phrase-editor-clarification#post-88</link>
                        <pubDate>Wed, 01 Jul 2020 18:40:55 +0000</pubDate>
                        <description><![CDATA[Thanks, I&#039;ll dig into this tomorrow.]]></description>
                        <content:encoded><![CDATA[<p>Thanks, I'll dig into this tomorrow.</p>]]></content:encoded>
                        <guid isPermaLink="true">http://forum.genoqs.net/community/support/phrase-editor-clarification#post-88</guid>
                        <link>http://forum.genoqs.net/community/support/phrase-editor-clarification#post-83</link>
                        <pubDate>Sun, 28 Jun 2020 13:22:12 +0000</pubDate>
                        <description><![CDATA[Hi Nick,The polyphony will set the max number of notes in the phrase that will be playedIf you input a chord (3 notes with the same STA value) &amp; set the poly to 1 then each time the phra...]]></description>
                        <content:encoded><![CDATA[<p>Hi Nick,</p><p>The polyphony will set the max number of notes in the phrase that will be played</p><p>If you input a chord (3 notes with the same STA value) &amp; set the poly to 1 then each time the phrase is triggered it will play just 1 note - a phrase type 3 or 4 will randomly play one of the chord notes.</p><p>There were quite a few timing bugs involving phrases that were resolved in v5.00.</p><p>The following info may help (copied from the v5 manual):-</p><p>Step phrase note variations<br />Setting the Step phrase to type 4 will randomize all programmed note<br />attributes so we can have a random note selection.<br />Here's how:- Zoom in to phrase edit and chose a phrase you want to edit, set the type to 4, then set note 2 to PIT +7 and set the polyphony to 1.<br />With a track set up as in example 1 above zoom into step 5 and set the step to the phrase number you have just created.<br />You will hear that step 5 will sometimes play the step note and sometimes the step note +7 semitones.<br />More variation can be added by increasing the number of PIT offsets in the phrase.</p><p>Step phrase timing variations<br />Again by setting the Step phrase to type 4, we can introduce a timing variation.<br />Here's how:- Zoom in to phrase edit and chose a phrase you want to edit, set the type to 4, then set note 2 to STA +12 and set the polyphony to 1.<br />With a track set up as in example 1 above zoom into step 1 and set the step to the phrase number you have just created.<br />You will notice that sometimes the step 1 note plays on step 1 and sometimes it plays on step 2.<br />Taking this a little further, set up a phrase as follows:<br />set the type to 4,<br />set note 2 to STA +12 and PIT +7<br />set note 3 to STA +24 and set the polyphony to 2.<br />Now, we change step 1 in example 1 to this new phrase and the following<br />variations can occur:- Step 1 &amp; step 2 play, or step 1 &amp; step 3 play, or step 2 &amp; step 3 play, AND one of the steps may, or may not, be offset by +7 semitones.</p><p> </p><p> </p>]]></content:encoded>
                        <category domain="https://forum.genoqs.net/community/support">Support</category>                        <dc:creator>Jean Blanc</dc:creator>
                        <guid isPermaLink="true">http://forum.genoqs.net/community/support/phrase-editor-clarification#post-83</guid>
                        <title>Phrase editor clarification</title>
                        <link>http://forum.genoqs.net/community/support/phrase-editor-clarification#post-82</link>
                        <pubDate>Sat, 27 Jun 2020 13:34:47 +0000</pubDate>
                        <description><![CDATA[Hi All. I&#039;ve been spending the lockdown devoting myself to the Octopus and have come up against a bit of a problem, I don&#039;t get this phrase (pun intended) from page 106 of the manual for OS ...]]></description>
                        <content:encoded><![CDATA[<p>Hi All.</p><p> </p><p>I've been spending the lockdown devoting myself to the Octopus and have come up against a bit of a problem, I don't get this phrase (pun intended) from page 106 of the manual for OS 1.62:</p><p> </p><p>'The 7 green note LEDs are mostly there to tell you that they may be<br />pressed: to set the optional phrase polyphony, press one of the note<br />buttons to make it blink orange. To restore the phrase to normal, full<br />polyphony, press the blinking note button again, and the blink will<br />disappear.'</p><p> </p><p>I have had just a single note in the phrase and tried pressing these buttons, it just seemed to space out the repetitions of the single note in an uneven and unpredictable way, although still in time. I assumed I could input chords but there is nothing in the display to allow me to do anything. Can anyone sort me out on this? What does this do?</p><p> </p><p>Thanks.</p>]]></content:encoded>
                        <guid isPermaLink="true">http://forum.genoqs.net/community/support/phrase-editor-clarification#post-82</guid>
