					                		Octopus gone dark on upgrade to OS5 - Support                                    </title>
                <link>http://forum.genoqs.net/community/support/octopus-gone-dark-on-upgrade-to-os5</link>
                <lastBuildDate>Sat, 12 Sep 2026 01:32:39 +0000</lastBuildDate>
                        <title>RE: Octopus gone dark on upgrade to OS5</title>
                        <link>http://forum.genoqs.net/community/support/octopus-gone-dark-on-upgrade-to-os5#post-112</link>
                        <pubDate>Sun, 11 Oct 2020 16:05:49 +0000</pubDate>
                        <description><![CDATA[@eellisHey Eric, no need, I got it sorted. Not being so much of a computer geek, I had forgotten that &#039;enter&#039; is not the same as &#039;return&#039;. Doh! Anyway, for anyone reading this, it&#039;s accessed...]]></description>
                        <content:encoded><![CDATA[<p>@eellis</p><p>Hey Eric, no need, I got it sorted. Not being so much of a computer geek, I had forgotten that 'enter' is not the same as 'return'. Doh! Anyway, for anyone reading this, it's accessed via a modifier + return key on new Macs, I think. I just dug out an ancient keyboard. Thanks for your help, once you pointed out that I wasn't uploading the file, I managed to figure it out.</p>]]></content:encoded>
                        <category domain="https://forum.genoqs.net/community/support">Support</category>                        <dc:creator>stratblue</dc:creator>
                        <guid isPermaLink="true">http://forum.genoqs.net/community/support/octopus-gone-dark-on-upgrade-to-os5#post-112</guid>
                        <link>http://forum.genoqs.net/community/support/octopus-gone-dark-on-upgrade-to-os5#post-111</link>
                        <pubDate>Sun, 11 Oct 2020 15:58:06 +0000</pubDate>
                        <description><![CDATA[Hey, I’ll be out for a bit and I need my computer to check. It may be the baud rate being too high, or one of the connection protocol check boxes. @handsfelloff knows a lot more about differ...]]></description>
                        <content:encoded><![CDATA[<p>Hey, I’ll be out for a bit and I need my computer to check. It may be the baud rate being too high, or one of the connection protocol check boxes. @handsfelloff knows a lot more about different terminal software. I’m guessing you’re on Mac and I run Linux so I’ll do my best. I’ll post in ~4 hours. </p>]]></content:encoded>
                        <category domain="https://forum.genoqs.net/community/support">Support</category>                        <dc:creator>Eric</dc:creator>
                        <guid isPermaLink="true">http://forum.genoqs.net/community/support/octopus-gone-dark-on-upgrade-to-os5#post-111</guid>
                        <link>http://forum.genoqs.net/community/support/octopus-gone-dark-on-upgrade-to-os5#post-110</link>
                        <pubDate>Sun, 11 Oct 2020 13:39:56 +0000</pubDate>
                        <description><![CDATA[@eellisI have tried a few times now, even being conscious of a timeout situation I did it as quickly as possible, I also tried loading it from a different folder. So what are these &#039;settings...]]></description>
                        <content:encoded><![CDATA[<p>@eellis</p><p>I have tried a few times now, even being conscious of a timeout situation I did it as quickly as possible, I also tried loading it from a different folder. So what are these 'settings' of which you speak....?</p>]]></content:encoded>
                        <guid isPermaLink="true">http://forum.genoqs.net/community/support/octopus-gone-dark-on-upgrade-to-os5#post-110</guid>
                        <link>http://forum.genoqs.net/community/support/octopus-gone-dark-on-upgrade-to-os5#post-109</link>
                        <pubDate>Sun, 11 Oct 2020 13:08:18 +0000</pubDate>
                        <description><![CDATA[Hm, I remember this has happened to me. Your terminal may be hanging up because the settings are off. Or, maybe it timed out again. After you issue the load command, you select your file and...]]></description>
                        <content:encoded><![CDATA[<p>Hm, I remember this has happened to me. Your terminal may be hanging up because the settings are off. Or, maybe it timed out again. After you issue the load command, you select your file and it should transfer, unless it times out. You will see the terminal print a character every second or so and after five or ten it gives up. If you send the file after it gives up, you will get a stuck transfer, which is what you have. I recommend you try again. </p>]]></content:encoded>
                        <guid isPermaLink="true">http://forum.genoqs.net/community/support/octopus-gone-dark-on-upgrade-to-os5#post-109</guid>
                        <link>http://forum.genoqs.net/community/support/octopus-gone-dark-on-upgrade-to-os5#post-108</link>
                        <pubDate>Sun, 11 Oct 2020 12:01:21 +0000</pubDate>
                        <description><![CDATA[Ok...this is what I have now: Screen-shot-2020-10-11-at-12.56.31.png I see no way to actually send the file, it just seems to hang with no progress bar movement. I realised also that the pdf...]]></description>
                        <content:encoded><![CDATA[<p>Ok...this is what I have now:</p><div id="wpfa-148" class="wpforo-attached-file"><a class="wpforo-default-attachment" href="//forum.genoqs.net/wp-content/uploads/wpforo/default_attachments/1602417681-Screen-shot-2020-10-11-at-125631.png" target="_blank" rel="noopener"> Screen-shot-2020-10-11-at-12.56.31.png</a></div><div> </div><div>I see no way to actually send the file, it just seems to hang with no progress bar movement. I realised also that the pdf I was following lacks the instructions to switch to 'binary data' in the transfer convert menu.</div>]]></content:encoded>
                        <guid isPermaLink="true">http://forum.genoqs.net/community/support/octopus-gone-dark-on-upgrade-to-os5#post-108</guid>
                        <link>http://forum.genoqs.net/community/support/octopus-gone-dark-on-upgrade-to-os5#post-107</link>
                        <pubDate>Sun, 11 Oct 2020 11:40:58 +0000</pubDate>
                        <description><![CDATA[Crikey Eric, that&#039;s quick, I just went to sit down in the garden and de stress! I&#039;ll try it now.]]></description>
                        <content:encoded><![CDATA[<p>Crikey Eric, that's quick, I just went to sit down in the garden and de stress! I'll try it now.</p>]]></content:encoded>
                        <guid isPermaLink="true">http://forum.genoqs.net/community/support/octopus-gone-dark-on-upgrade-to-os5#post-107</guid>
                        <link>http://forum.genoqs.net/community/support/octopus-gone-dark-on-upgrade-to-os5#post-106</link>
                        <pubDate>Sun, 11 Oct 2020 11:34:18 +0000</pubDate>
                        <description><![CDATA[Hey Nick,From the terminal output it looks like you issued the command to load the ELF file but you didn’t actually send it using your terminal. Then, I think you saved ... a failed transfer...]]></description>
                        <content:encoded><![CDATA[<p>Hey Nick,</p><p>From the terminal output it looks like you issued the command to load the ELF file but you didn’t actually send it using your terminal. Then, I think you saved ... a failed transfer to NAND memory (flash). Now the boot loader can’t start the machine because the OS is missing. You should be able to transfer the ELF successfully, save it and get the machine back. The bootloader is stored in a different location so I don’t think there is anything wrong. Just be careful to double check the commands, or copy/paste directly from the guide. <br /><br /></p><p>We can help you transfer using the terminal. You need to select the file before it times out. It looks like you took too long :/ it will take about 3 mins and you’ll see a progress bar in the terminal UI. </p>]]></content:encoded>
                        <guid isPermaLink="true">http://forum.genoqs.net/community/support/octopus-gone-dark-on-upgrade-to-os5#post-106</guid>
                        <title>Octopus gone dark on upgrade to OS5</title>
                        <link>http://forum.genoqs.net/community/support/octopus-gone-dark-on-upgrade-to-os5#post-105</link>
                        <pubDate>Sun, 11 Oct 2020 11:18:11 +0000</pubDate>
                        <description><![CDATA[Hi there. tried to update to the new OS 5 but I have run into a problem. The Octopus display is dark but if i restart it or reset using the red button I can see the boot sequence in Zterm Sc...]]></description>
                        <content:encoded><![CDATA[<p>Hi there.</p><p> </p><p>tried to update to the new OS 5 but I have run into a problem. The Octopus display is dark but if i restart it or reset using the red button I can see the boot sequence in Zterm</p><div id="wpfa-144" class="wpforo-attached-file"><a class="wpforo-default-attachment" href="//forum.genoqs.net/wp-content/uploads/wpforo/default_attachments/1602415142-Screen-shot-2020-10-11-at-120828.png" target="_blank" rel="noopener"> Screen-shot-2020-10-11-at-12.08.28.png</a>,</div><div id="wpfa-145" class="wpforo-attached-file"><a class="wpforo-default-attachment" href="//forum.genoqs.net/wp-content/uploads/wpforo/default_attachments/1602415161-Screen-shot-2020-10-11-at-121027.png" target="_blank" rel="noopener"> Screen-shot-2020-10-11-at-12.10.27.png</a>,</div><div id="wpfa-146" class="wpforo-attached-file"><a class="wpforo-default-attachment" href="//forum.genoqs.net/wp-content/uploads/wpforo/default_attachments/1602415186-Screen-shot-2020-10-11-at-121102.png" target="_blank" rel="noopener"> Screen-shot-2020-10-11-at-12.11.02.png</a>,</div><div id="wpfa-147" class="wpforo-attached-file"><a class="wpforo-default-attachment" href="//forum.genoqs.net/wp-content/uploads/wpforo/default_attachments/1602415203-Screen-shot-2020-10-11-at-121133.png" target="_blank" rel="noopener"> Screen-shot-2020-10-11-at-12.11.33.png</a></div><div> </div><div>I get error: 6 in SerGetBuf when I start it. Any ideas where to go from here?</div><div> </div><div>Thanks.</div>]]></content:encoded>
                        <guid isPermaLink="true">http://forum.genoqs.net/community/support/octopus-gone-dark-on-upgrade-to-os5#post-105</guid>
