					                		Octopus + Daw Setup - Support                                    </title>
                <link>http://forum.genoqs.net/community/support/octopus-daw-setup</link>
                <lastBuildDate>Fri, 13 Nov 2026 07:30:26 +0000</lastBuildDate>
                        <title>RE: Octopus + Daw Setup</title>
                        <link>http://forum.genoqs.net/community/support/octopus-daw-setup#post-65</link>
                        <pubDate>Fri, 01 May 2020 16:40:05 +0000</pubDate>
                        <description><![CDATA[Thanks Eric. I&#039;ll see if I can figure this out.Carlos]]></description>
                        <content:encoded><![CDATA[<p>Thanks Eric. I'll see if I can figure this out.</p><p>Carlos</p>]]></content:encoded>
                        <category domain="https://forum.genoqs.net/community/support">Support</category>                        <dc:creator>Carlos</dc:creator>
                        <guid isPermaLink="true">http://forum.genoqs.net/community/support/octopus-daw-setup#post-65</guid>
                        <link>http://forum.genoqs.net/community/support/octopus-daw-setup#post-64</link>
                        <pubDate>Thu, 30 Apr 2020 23:29:29 +0000</pubDate>
                        <description><![CDATA[Hi Carlos,Everyone has unique equipment so we can probably fill in blanks. I know member: stratblue works primarily with a DAW. This attached diagram may be helpful. There were some timing a...]]></description>
                        <content:encoded><![CDATA[<p>Hi Carlos,</p><p>Everyone has unique equipment so we can probably fill in blanks. I know member: <a title="stratblue" href="http://forum.genoqs.net/community/profile/stratblue">stratblue</a> works primarily with a DAW. This attached diagram may be helpful. There were some timing and clock signal considerations when I setup MIDI Master or Slave with my Octopus and Logic Pro X. I needed to use two different MIDI to USB routers. We also have an experimental OS version for the Octopus and Nemo that allows you to "anti-echo", i.e. disable MDI CC feedback loops.</p><p>Cheers,</p><p>Eric</p>
<div id="wpfa-137" class="wpforo-attached-file"><a class="wpforo-default-attachment" href="//forum.genoqs.net/wp-content/uploads/wpforo/default_attachments/1588289369-Screen-Shot-2018-06-01-at-41050-PM.png" target="_blank"><i class="fas fa-paperclip"></i>&nbsp;Screen-Shot-2018-06-01-at-4.10.50-PM.png</a></div>]]></content:encoded>
                        <category domain="https://forum.genoqs.net/community/support">Support</category>                        <dc:creator>Eric</dc:creator>
                        <guid isPermaLink="true">http://forum.genoqs.net/community/support/octopus-daw-setup#post-64</guid>
                        <title>Octopus + Daw Setup</title>
                        <link>http://forum.genoqs.net/community/support/octopus-daw-setup#post-63</link>
                        <pubDate>Thu, 30 Apr 2020 23:01:41 +0000</pubDate>
                        <description><![CDATA[Forgive me if this seems basic to you all but I want to make sure I am doing this correctly.I want to hook up Octopus to a Daw and sequence VIs and also sequence external synths.I have sever...]]></description>
                        <content:encoded><![CDATA[<p>Forgive me if this seems basic to you all but I want to make sure I am doing this correctly.</p><p>I want to hook up Octopus to a Daw and sequence VIs and also sequence external synths.</p><p>I have several Midi Time Pieces XT I can use (8 in / 8 out). </p><p>let's say I have 9 tracks on the DAW each with its own VI. I want to use each of the 9 tracks in the Octopus to sequence each of the 9 tracks in the Daw each with a different VI.</p><p>So Octopus Port 1 would be used for sequencing in the DAW, and port 2 to sequence 14 external synths I already have connected on one of the MTP with a configuration made in MOTU's Clockworks so that the MTP port 1 is connected to all 8 MTP outputs and then I would use the mute function so that output 1 on the MTP only sends data on channel 1, output 2 only sends data on channel 2 and so on.</p><p> </p><p>Can anyone give a step by step guide on how I would need to set this up with the external synths and a DAW? I use Logic, PT, LIVE, DP, Cubase, Nuendo.</p><p>Thank you in advance.</p><p>Carlos</p><p> </p>]]></content:encoded>
                        <guid isPermaLink="true">http://forum.genoqs.net/community/support/octopus-daw-setup#post-63</guid>
