					                		Mac OSX Operating System Update Guide - Support                                    </title>
                <link>http://forum.genoqs.net/community/support/mac-osx-operating-system-update-guide</link>
                <lastBuildDate>Fri, 13 Nov 2026 08:35:47 +0000</lastBuildDate>
                        <title>RE: Mac OSX Operating System Update Guide</title>
                        <link>http://forum.genoqs.net/community/support/mac-osx-operating-system-update-guide#post-216</link>
                        <pubDate>Wed, 21 Jul 2021 13:33:21 +0000</pubDate>
                        <description><![CDATA[@companyofquail
I&#039;m pleased to hear all well  - enjoy CE v5.00 !!]]></description>
                        <content:encoded><![CDATA[<p>@companyofquail</p>
<p>I'm pleased to hear all well  - enjoy CE v5.00 !!</p>]]></content:encoded>
                        <category domain="https://forum.genoqs.net/community/support">Support</category>                        <dc:creator>Jean Blanc</dc:creator>
                        <guid isPermaLink="true">http://forum.genoqs.net/community/support/mac-osx-operating-system-update-guide#post-216</guid>
                        <link>http://forum.genoqs.net/community/support/mac-osx-operating-system-update-guide#post-215</link>
                        <pubDate>Tue, 20 Jul 2021 12:22:37 +0000</pubDate>
                        <description><![CDATA[just wanted to follow up, i changed the file name and it installed no problem at all.  thanks so much for the reminder. it had been nearly 4 years since i had done this and it was a little f...]]></description>
                        <content:encoded><![CDATA[<p>just wanted to follow up, i changed the file name and it installed no problem at all.  thanks so much for the reminder. it had been nearly 4 years since i had done this and it was a little foggy. </p>]]></content:encoded>
                        <category domain="https://forum.genoqs.net/community/support">Support</category>                        <dc:creator>companyofquail</dc:creator>
                        <guid isPermaLink="true">http://forum.genoqs.net/community/support/mac-osx-operating-system-update-guide#post-215</guid>
                        <link>http://forum.genoqs.net/community/support/mac-osx-operating-system-update-guide#post-214</link>
                        <pubDate>Sat, 10 Jul 2021 12:26:11 +0000</pubDate>
                        <description><![CDATA[@jean ah. I see. I changed the file name bc I was using the full file name of the download and it was too long. This makes sense. I’ll try that]]></description>
                        <content:encoded><![CDATA[<p>@jean ah. I see. I changed the file name bc I was using the full file name of the download and it was too long. This makes sense. I’ll try that </p>]]></content:encoded>
                        <guid isPermaLink="true">http://forum.genoqs.net/community/support/mac-osx-operating-system-update-guide#post-214</guid>
                        <link>http://forum.genoqs.net/community/support/mac-osx-operating-system-update-guide#post-213</link>
                        <pubDate>Sat, 10 Jul 2021 12:24:25 +0000</pubDate>
                        <description><![CDATA[The boot from memory address is   &#039;go 0x00010040&#039;]]></description>
                        <content:encoded><![CDATA[<p>The boot from memory address is   'go 0x00010040'</p>
<p> </p>]]></content:encoded>
                        <guid isPermaLink="true">http://forum.genoqs.net/community/support/mac-osx-operating-system-update-guide#post-213</guid>
                        <link>http://forum.genoqs.net/community/support/mac-osx-operating-system-update-guide#post-212</link>
                        <pubDate>Sat, 10 Jul 2021 12:22:07 +0000</pubDate>
Hi,  I see from you screenshot you have typed the filename &#039;NEMO500.elf - the fis create name must be NEMO_OS.elf (even if the file you have loaded into flash has a differen...]]></description>
<p>Hi,  I see from you screenshot you have typed the filename 'NEMO500.elf - the fis create name must be NEMO_OS.elf (even if the file you have loaded into flash has a different elf name).</p>
<p>Best,</p>
<p>Jean</p>]]></content:encoded>
                        <guid isPermaLink="true">http://forum.genoqs.net/community/support/mac-osx-operating-system-update-guide#post-212</guid>
                        <link>http://forum.genoqs.net/community/support/mac-osx-operating-system-update-guide#post-211</link>
                        <pubDate>Fri, 09 Jul 2021 23:20:29 +0000</pubDate>
I think that means v1.6 which wouldn&#039;t have the upgrade issue.
Probably the next thing to do is upgrade without running the last step to flash. You can boot in-memory inste...]]></description>
<p>I think that means v1.6 which wouldn't have the upgrade issue.</p>
<p>Probably the next thing to do is upgrade without running the last step to flash. You can boot in-memory instead. I don't have the run command in front of me but I know Wilson had posted it here somewhere when helping someone else.</p>]]></content:encoded>
                        <category domain="https://forum.genoqs.net/community/support">Support</category>                        <dc:creator>Eric</dc:creator>
                        <guid isPermaLink="true">http://forum.genoqs.net/community/support/mac-osx-operating-system-update-guide#post-211</guid>
                        <link>http://forum.genoqs.net/community/support/mac-osx-operating-system-update-guide#post-210</link>
                        <pubDate>Fri, 09 Jul 2021 22:44:30 +0000</pubDate>
                        <description><![CDATA[Don’t have the unit in front of me at the moment but it I remember correctly steps 1-6 were lit red and I believe step 9 was lit red.]]></description>
                        <content:encoded><![CDATA[<p>Don’t have the unit in front of me at the moment but it I remember correctly steps 1-6 were lit red and I believe step 9 was lit red. </p>]]></content:encoded>
                        <guid isPermaLink="true">http://forum.genoqs.net/community/support/mac-osx-operating-system-update-guide#post-210</guid>
                        <link>http://forum.genoqs.net/community/support/mac-osx-operating-system-update-guide#post-209</link>
                        <pubDate>Fri, 09 Jul 2021 22:33:14 +0000</pubDate>
Hi, there are some extra upgrade steps if the Nemo is running a really old OS version. Can you restart in System View and check which OS version is currently installed. Post...]]></description>
<p>Hi, there are some extra upgrade steps if the Nemo is running a really old OS version. Can you restart in System View and check which OS version is currently installed. Post a photo if the LEDs don't make sense. 🧐 </p>]]></content:encoded>
                        <guid isPermaLink="true">http://forum.genoqs.net/community/support/mac-osx-operating-system-update-guide#post-209</guid>
                        <link>http://forum.genoqs.net/community/support/mac-osx-operating-system-update-guide#post-208</link>
                        <pubDate>Fri, 09 Jul 2021 22:22:31 +0000</pubDate>
                        <description><![CDATA[Trying to update a friends Nemo to CE and keep getting error below in hyperterm. Using Windows XP. No problems a few years ago updating a octopus and Nemo with same system. 
“Invalid flash ...]]></description>
                        <content:encoded><![CDATA[<p>Trying to update a friends Nemo to CE and keep getting error below in hyperterm. Using Windows XP. No problems a few years ago updating a octopus and Nemo with same system. <br /><br /></p>
<p>“Invalid flash address - not free”</p>
<p>any suggestions? </p>
<div id="wpfa-172" class="wpforo-attached-file"><a class="wpforo-default-attachment" href="//forum.genoqs.net/wp-content/uploads/wpforo/default_attachments/1625869351-2BE3751F-1BE0-4951-B08A-780F725E570F.jpeg" target="_blank"><i class="fas fa-paperclip"></i>&nbsp;2BE3751F-1BE0-4951-B08A-780F725E570F.jpeg</a></div>]]></content:encoded>
                        <guid isPermaLink="true">http://forum.genoqs.net/community/support/mac-osx-operating-system-update-guide#post-208</guid>
                        <link>http://forum.genoqs.net/community/support/mac-osx-operating-system-update-guide#post-173</link>
                        <pubDate>Mon, 19 Apr 2021 07:29:30 +0000</pubDate>
                        <description><![CDATA[Hi Eric,
Thanks very much for the post.
Terminal settings are the same here and I am sending the file pretty quickly, one &quot;C&quot; has been logged.
I have tried forcing ymodem mode and binary ...]]></description>
                        <content:encoded><![CDATA[<p>Hi Eric,</p>
<p>Thanks very much for the post.</p>
<p>Terminal settings are the same here and I am sending the file pretty quickly, one "C" has been logged.</p>
<p>I have tried forcing ymodem mode and binary mode: lsz -b --ymodem ...</p>
<p>It's just really strange it cancels at exactly the same place on each machine, all are using lsz though.</p>
<p>I'm trying to track down an XP VM I have somewhere to try hyper term, otherwise I have JTAG gear here so I could maybe rip it apart and use openocd, that at the moment is last resort though :)</p>
<p>Cheers</p>
<p>Andy</p>]]></content:encoded>
                        <category domain="https://forum.genoqs.net/community/support">Support</category>                        <dc:creator>AndyCap</dc:creator>
                        <guid isPermaLink="true">http://forum.genoqs.net/community/support/mac-osx-operating-system-update-guide#post-173</guid>
