					                		internal resolution? - Support                                    </title>
                <link>http://forum.genoqs.net/community/support/internal-resolution</link>
                <lastBuildDate>Sat, 12 Sep 2026 01:45:45 +0000</lastBuildDate>
                        <title>RE: internal resolution?</title>
                        <link>http://forum.genoqs.net/community/support/internal-resolution#post-261</link>
                        <pubDate>Wed, 08 Jun 2022 15:10:09 +0000</pubDate>
                        <description><![CDATA[Hi,
The Octopus will always run at 192 ticks per step as its internal resolution for note start offsets. I believe the clock pulse per quarter note MIDI should be 24. If you send 192 the Oc...]]></description>
                        <content:encoded><![CDATA[<p>Hi,</p>
<p>The Octopus will always run at 192 ticks per step as its internal resolution for note start offsets. I believe the clock pulse per quarter note MIDI should be 24. If you send 192 the Octopus will probably just run 8x as fast (or its max speed which is somewhere around 200bpm).</p>]]></content:encoded>
                        <category domain="https://forum.genoqs.net/community/support">Support</category>                        <dc:creator>Eric</dc:creator>
                        <guid isPermaLink="true">http://forum.genoqs.net/community/support/internal-resolution#post-261</guid>
                        <title>internal resolution?</title>
                        <link>http://forum.genoqs.net/community/support/internal-resolution#post-260</link>
                        <pubDate>Wed, 08 Jun 2022 10:53:04 +0000</pubDate>
                        <description><![CDATA[i was curious if the internal resolution of the nemo and octopus remains at 192ppq when you put a 24ppq clock into it? i know some sequencers lower their resolution to follow the external cl...]]></description>
                        <content:encoded><![CDATA[<p>i was curious if the internal resolution of the nemo and octopus remains at 192ppq when you put a 24ppq clock into it? i know some sequencers lower their resolution to follow the external clock and some sequencers "add the ticks in"</p>]]></content:encoded>
                        <category domain="https://forum.genoqs.net/community/support">Support</category>                        <dc:creator>companyofquail</dc:creator>
                        <guid isPermaLink="true">http://forum.genoqs.net/community/support/internal-resolution#post-260</guid>
