					                		Ive added new features to my Octopus - New features                                    </title>
                <link>https://forum.genoqs.net/community/new-features/ive-added-new-features-to-my-octopus</link>
                <lastBuildDate>Thu, 08 Oct 2026 07:09:30 +0000</lastBuildDate>
                        <title>RE: Ive added new features to my Octopus</title>
                        <link>http://forum.genoqs.net/community/new-features/ive-added-new-features-to-my-octopus#post-297</link>
                        <pubDate>Wed, 29 Apr 2026 16:58:42 +0000</pubDate>
                        <description><![CDATA[@eellis this is exactly what i did. i loaded everything i could find on genoqs including the forum and any pdf into my claude workspace and taught it all about the machines by many q and a s...]]></description>
                        <content:encoded><![CDATA[<p>@eellis this is exactly what i did. i loaded everything i could find on genoqs including the forum and any pdf into my claude workspace and taught it all about the machines by many q and a sessions as well as giving it context for how the code and the documentation differ/work together. <br /><br />its wild how much you can get done with all this. i was creating multiple features per day with very few bugs (mostly just LED stuff), it was wild</p>]]></content:encoded>
                        <category domain="http://forum.genoqs.net/community/new-features">New features</category>                        <dc:creator>companyofquail</dc:creator>
                        <guid isPermaLink="true">http://forum.genoqs.net/community/new-features/ive-added-new-features-to-my-octopus#post-297</guid>
                        <link>http://forum.genoqs.net/community/new-features/ive-added-new-features-to-my-octopus#post-296</link>
                        <pubDate>Wed, 29 Apr 2026 05:16:04 +0000</pubDate>
                        <description><![CDATA[Very cool! I&#039;ve been thinking about doing the same thing to fix the timing issue in my feature branch. The codebase is small enough for the AI to generate context `.md` files about the code ...]]></description>
                        <content:encoded><![CDATA[<p>Very cool! I've been thinking about doing the same thing to fix the timing issue in my feature branch. The codebase is small enough for the AI to generate context `.md` files about the code and use that to make just about any change within minutes. I'd feed the AI the manual, then tell it to create a plan to run across several sessions to generate the context files with a root context. Then when you want it to do something just load the root context file and it will load whatever else it needs, context, code. </p>
<p>Maybe ask it to write an emulator harness with unit tests for every feature/capability. Then ask it to rewrite all of the code in Rust. Then ask it to write a VST UI to use it as a direct MIDI controller in a DAW for high resolution and zero latency grid recording... The ideas keep coming.</p>]]></content:encoded>
                        <category domain="http://forum.genoqs.net/community/new-features">New features</category>                        <dc:creator>Eric</dc:creator>
                        <guid isPermaLink="true">http://forum.genoqs.net/community/new-features/ive-added-new-features-to-my-octopus#post-296</guid>
                        <title>Ive added new features to my Octopus</title>
                        <link>http://forum.genoqs.net/community/new-features/ive-added-new-features-to-my-octopus#post-295</link>
                        <pubDate>Mon, 27 Apr 2026 16:01:40 +0000</pubDate>
                        <description><![CDATA[we use Claude at work so i decided to let it take a crack at genoQs code. 
it worked! 
so after years of wanting to make a few changes like adding the flow shapes from NEMO and incorporati...]]></description>
                        <content:encoded><![CDATA[<p>we use Claude at work so i decided to let it take a crack at genoQs code. </p>
<p>it worked! </p>
<p>so after years of wanting to make a few changes like adding the flow shapes from NEMO and incorporating a better chord mode, and bringing back some older features we are now here. i will share the actual elf and code once i have time to make sure more bugs have been ironed out. right now all these features run and dont crash, there are a few small things i have to fix with LEDs either being lit or not lit. <br /><br />here is a pdf explaining all the new features</p>
<div id="wpfa-188" class="wpforo-attached-file"><a class="wpforo-default-attachment" href="//forum.genoqs.net/wp-content/uploads/wpforo/default_attachments/1777305700-Octopus_Reference_CE_Addendum_v590.pdf" target="_blank"><i class="fas fa-paperclip"></i>&nbsp;Octopus_Reference_CE_Addendum_v590.pdf</a></div>]]></content:encoded>
                        <guid isPermaLink="true">http://forum.genoqs.net/community/new-features/ive-added-new-features-to-my-octopus#post-295</guid>
