					                		Velocity Attribute Maps - Dev Den                                    </title>
                <link>http://forum.genoqs.net/community/dev-den/velocity-attribute-maps</link>
                <lastBuildDate>Thu, 13 Aug 2026 21:50:15 +0000</lastBuildDate>
                        <title>RE: Velocity Attribute Maps</title>
                        <link>http://forum.genoqs.net/community/dev-den/velocity-attribute-maps#post-203</link>
                        <pubDate>Mon, 17 May 2021 10:37:03 +0000</pubDate>
                        <description><![CDATA[Interesting idea Nick, yes the values of VEL (&amp; the other attr&#039;s) are preset in the code but having a way of changing the values would add flexibility &amp; a lot more power to the maps ...]]></description>
                        <content:encoded><![CDATA[<p>Interesting idea Nick, yes the values of VEL (&amp; the other attr's) are preset in the code but having a way of changing the values would add flexibility &amp; a lot more power to the maps (in addition to setting the values perhaps the neutral row (5) could also be moved up/down in the matrix).</p>
<p>Not sure how the go about at this stage - but will give it some thought for future possibilities.</p>
<p>Best,</p>
<p>Jean</p>]]></content:encoded>
                        <category domain="http://forum.genoqs.net/community/dev-den">Dev Den</category>                        <dc:creator>Jean Blanc</dc:creator>
                        <guid isPermaLink="true">http://forum.genoqs.net/community/dev-den/velocity-attribute-maps#post-203</guid>
                        <link>http://forum.genoqs.net/community/dev-den/velocity-attribute-maps#post-186</link>
                        <pubDate>Tue, 11 May 2021 21:58:29 +0000</pubDate>
                        <description><![CDATA[I myself, am not planning to implement any new features beyond what has been added in v6. I expect that I&#039;ll have the remaining bugs/issues fixed in the next few months during heat waves whe...]]></description>
                        <content:encoded><![CDATA[<p>I myself, am not planning to implement any new features beyond what has been added in v6. I expect that I'll have the remaining bugs/issues fixed in the next few months during heat waves when my air conditioning is too loud.</p>]]></content:encoded>
                        <category domain="http://forum.genoqs.net/community/dev-den">Dev Den</category>                        <dc:creator>Eric</dc:creator>
                        <guid isPermaLink="true">http://forum.genoqs.net/community/dev-den/velocity-attribute-maps#post-186</guid>
                        <title>Velocity Attribute Maps</title>
                        <link>http://forum.genoqs.net/community/dev-den/velocity-attribute-maps#post-185</link>
                        <pubDate>Mon, 10 May 2021 11:27:49 +0000</pubDate>
                        <description><![CDATA[Hi there.
I work with velocity switched samples a lot these days and it seems that although I can manipulate the velocity of a note in the attribute map in the outer circle it would be real...]]></description>
                        <content:encoded><![CDATA[<p>Hi there.</p>
<p>I work with velocity switched samples a lot these days and it seems that although I can manipulate the velocity of a note in the attribute map in the outer circle it would be really handy if each layer in the attribute map could be assigned a volume, currently they are set at 29,39,49,59,64,69,79,89 and 99 and I see no way to alter these on a per page basis. Is this a functionality that has been considered for future updates?</p>
<p>Thanks.</p>]]></content:encoded>
                        <category domain="http://forum.genoqs.net/community/dev-den">Dev Den</category>                        <dc:creator>stratblue</dc:creator>
                        <guid isPermaLink="true">http://forum.genoqs.net/community/dev-den/velocity-attribute-maps#post-185</guid>
