					                		Strange behaviour. - Dev Den                                    </title>
                <link>http://forum.genoqs.net/community/dev-den/strange-behaviour</link>
                <lastBuildDate>Sat, 12 Sep 2026 01:27:16 +0000</lastBuildDate>
                        <title>RE: Strange behaviour.</title>
                        <link>http://forum.genoqs.net/community/dev-den/strange-behaviour#post-160</link>
                        <pubDate>Sat, 20 Feb 2021 16:35:29 +0000</pubDate>
                        <description><![CDATA[Nice one thanks for clarifying that.]]></description>
                        <content:encoded><![CDATA[<p>Nice one thanks for clarifying that.</p>]]></content:encoded>
                        <category domain="http://forum.genoqs.net/community/dev-den">Dev Den</category>                        <dc:creator>stratblue</dc:creator>
                        <guid isPermaLink="true">http://forum.genoqs.net/community/dev-den/strange-behaviour#post-160</guid>
                        <link>http://forum.genoqs.net/community/dev-den/strange-behaviour#post-159</link>
                        <pubDate>Sat, 20 Feb 2021 11:23:56 +0000</pubDate>
                        <description><![CDATA[Hi Nick,
That is not a bug, you have set a Step Event on the step(s) - hence the led is yellow.
You will see that when you are zoomed into the step the attribute GRV led is flashing signif...]]></description>
                        <content:encoded><![CDATA[<p>Hi Nick,</p>
<p>That is not a bug, you have set a Step Event on the step(s) - hence the led is yellow.</p>
<p>You will see that when you are zoomed into the step the attribute GRV led is flashing signifying a GRV Step Event - click it once  to turn off the designation of Step Event (&amp; the led will be solid yellow). </p>
<p>Best,</p>
<p>Jean</p>]]></content:encoded>
                        <category domain="http://forum.genoqs.net/community/dev-den">Dev Den</category>                        <dc:creator>Jean Blanc</dc:creator>
                        <guid isPermaLink="true">http://forum.genoqs.net/community/dev-den/strange-behaviour#post-159</guid>
                        <title>Strange behaviour.</title>
                        <link>http://forum.genoqs.net/community/dev-den/strange-behaviour#post-158</link>
                        <pubDate>Sat, 20 Feb 2021 08:59:05 +0000</pubDate>
                        <description><![CDATA[Hi there.
I created a phrase with 16th note triplets in the phrase editor then pasted that step onto alternate steps and it worked as expected but the steps illuminated yellow and I coul...]]></description>
                        <content:encoded><![CDATA[<p>Hi there.</p>
<p>I created a phrase with 16th note triplets in the phrase editor then pasted that step onto alternate steps and it worked as expected but the steps illuminated yellow and I couldn't toggle the LED off despite being able to toggle the sound.</p>
<div id="wpfa-158" class="wpforo-attached-file"><a class="wpforo-default-attachment" href="//forum.genoqs.net/wp-content/uploads/wpforo/default_attachments/1613811545-Archive.zip" target="_blank"><i class="fas fa-paperclip"></i>&nbsp;Archive.zip</a></div>]]></content:encoded>
                        <guid isPermaLink="true">http://forum.genoqs.net/community/dev-den/strange-behaviour#post-158</guid>
