					                		Octopus (only) v6 BETA - Dev Den                                    </title>
                <link>https://forum.genoqs.net/community/dev-den/octopus-only-v6-beta</link>
                <lastBuildDate>Sat, 12 Sep 2026 01:49:32 +0000</lastBuildDate>
                        <title>RE: Octopus (only) v6 BETA</title>
                        <link>http://forum.genoqs.net/community/dev-den/octopus-only-v6-beta/paged/2#post-273</link>
                        <pubDate>Mon, 16 Jan 2023 18:24:21 +0000</pubDate>
                        <description><![CDATA[@eellis
You&#039;re welcome, let me know if I can help with anything else.]]></description>
                        <content:encoded><![CDATA[<p>@eellis</p>
<p>You're welcome, let me know if I can help with anything else.</p>]]></content:encoded>
                        <category domain="http://forum.genoqs.net/community/dev-den">Dev Den</category>                        <dc:creator>stratblue</dc:creator>
                        <guid isPermaLink="true">http://forum.genoqs.net/community/dev-den/octopus-only-v6-beta/paged/2#post-273</guid>
                        <link>http://forum.genoqs.net/community/dev-den/octopus-only-v6-beta/paged/2#post-272</link>
                        <pubDate>Sun, 15 Jan 2023 18:20:45 +0000</pubDate>
                        <description><![CDATA[The before timing test showing crazy note overlap when recording a 4x4 loop.
&nbsp;Screenshot-2023-01-14-at-1.08.24-PM.png]]></description>
                        <content:encoded><![CDATA[<p>The before timing test showing crazy note overlap when recording a 4x4 loop.</p>
<div id="wpfa-186" class="wpforo-attached-file"><a class="wpforo-default-attachment" href="//forum.genoqs.net/wp-content/uploads/wpforo/default_attachments/1673806845-Screenshot-2023-01-14-at-10824-PM.png" target="_blank"><i class="fas fa-paperclip"></i>&nbsp;Screenshot-2023-01-14-at-1.08.24-PM.png</a></div>]]></content:encoded>
                        <category domain="http://forum.genoqs.net/community/dev-den">Dev Den</category>                        <dc:creator>Eric</dc:creator>
                        <guid isPermaLink="true">http://forum.genoqs.net/community/dev-den/octopus-only-v6-beta/paged/2#post-272</guid>
                        <link>http://forum.genoqs.net/community/dev-den/octopus-only-v6-beta/paged/2#post-271</link>
                        <pubDate>Sun, 15 Jan 2023 18:19:18 +0000</pubDate>
                        <description><![CDATA[Hey Nick, that was a huge help! I&#039;ve been working a lot and recently have been switching some gear around and did notice a timing issue but thought it may be a latency resolution issue. I sp...]]></description>
                        <content:encoded><![CDATA[<p>Hey Nick, that was a huge help! I've been working a lot and recently have been switching some gear around and did notice a timing issue but thought it may be a latency resolution issue. I spent 4h yesterday going through all of my code using Logic Pro as my test, which clearly showed the issue. It turns out that one of my last commits (also just before I had to focus on work) was to merge from master. When I reverted that merge the timing bug went away. I didn't go as far as to debug further because I had already spent my Saturday tracking down the issue.</p>
<p>https://github.com/genoqs-community/source/commit/6caa545edb19b451154ec24534c56a44e789c6e6</p>
<p><strong>Next steps:</strong></p>
<ol>
<li>I have no plans at this point to merge the master branch back into my Cuttlefish branch - yes, if the timing bug is fixed</li>
<li>I still need to fix the two bugs that I mentioned
<ol>
<li>I don't yet know how to reproduce the undo bug</li>
<li>The Play Along same MIDI channel bug isn't really a bug, so I may not fix it</li>
</ol>
</li>
</ol>
<p>Here is the latest ELF which runs but hasn't been checked for any regression issues that may have been caused by the master revert.</p>
<p>https://github.com/genoqs-community/source/blob/6caa545edb19b451154ec24534c56a44e789c6e6/OCT_OS/octopus.elf</p>
<p>See the attached screenshots for proof that the timing bug is real and is now fixed. Thanks again!</p>
<div id="wpfa-185" class="wpforo-attached-file"><a class="wpforo-default-attachment" href="//forum.genoqs.net/wp-content/uploads/wpforo/default_attachments/1673806758-Screenshot-2023-01-14-at-41238-PM.png" target="_blank"><i class="fas fa-paperclip"></i>&nbsp;Screenshot-2023-01-14-at-4.12.38-PM.png</a></div>]]></content:encoded>
                        <guid isPermaLink="true">http://forum.genoqs.net/community/dev-den/octopus-only-v6-beta/paged/2#post-271</guid>
                        <link>http://forum.genoqs.net/community/dev-den/octopus-only-v6-beta/paged/2#post-270</link>
                        <pubDate>Tue, 10 Jan 2023 10:28:23 +0000</pubDate>
                        <description><![CDATA[Hey there.
I have been trying out OS6 but unfortunately my TR8s will not keep time with the Octo running 6, it will drift to 16th note out in no time. I have just downgraded back to 5 an...]]></description>
                        <content:encoded><![CDATA[<p>Hey there.</p>
<p>I have been trying out OS6 but unfortunately my TR8s will not keep time with the Octo running 6, it will drift to 16th note out in no time. I have just downgraded back to 5 and it syncs up perfectly, nothing else in the setup I'm using was altered. Not sure if it's at all relevant but in 5 one click of the 200 button activates clock send, it takes two clicks on 6 to get to the same state, green illumination comes before yellow.</p>
<p>Nick.</p>]]></content:encoded>
                        <guid isPermaLink="true">http://forum.genoqs.net/community/dev-den/octopus-only-v6-beta/paged/2#post-270</guid>
                        <link>http://forum.genoqs.net/community/dev-den/octopus-only-v6-beta/paged/2#post-269</link>
                        <pubDate>Wed, 28 Dec 2022 20:01:33 +0000</pubDate>
                        <description><![CDATA[Hey Eric.
Thanks for clarifying that.]]></description>
                        <content:encoded><![CDATA[<p>Hey Eric.</p>
<p>Thanks for clarifying that.</p>]]></content:encoded>
                        <guid isPermaLink="true">http://forum.genoqs.net/community/dev-den/octopus-only-v6-beta/paged/2#post-269</guid>
                        <link>http://forum.genoqs.net/community/dev-den/octopus-only-v6-beta/paged/2#post-268</link>
                        <pubDate>Wed, 28 Dec 2022 16:29:17 +0000</pubDate>
                        <description><![CDATA[@stratblue
Hey, sorry about the confusion. I&#039;ll update the manual to specify which extra features are only available in SoloRec View. A general rule of thumb will be that almost all of the ...]]></description>
                        <content:encoded><![CDATA[<p>@stratblue</p>
<p>Hey, sorry about the confusion. I'll update the manual to specify which extra features are only available in SoloRec View. A general rule of thumb will be that almost all of the v6 features are SoloRec only. To get into that view go to the Grid View. While the sequencer is stopped, press PAUSE. I put the new features in here so that I wouldn't need to contend with the existing UI. You'll need to select a grid page and pick the number of bars, record some midi notes with an external keyboard, and then most of the new capabilities will light up for you.</p>
<p>There are two known bugs that I'll be fixing soon. Undo notes sometimes show up when you hit play. You can double click "X" for undo-clear or just undo as a workaround. And with Play Along pages, if they use the same MIDI channel as the channel you are recording into then the Play Along notes will also record.</p>
<p>Best,</p>
<p>Eric</p>]]></content:encoded>
                        <guid isPermaLink="true">http://forum.genoqs.net/community/dev-den/octopus-only-v6-beta/paged/2#post-268</guid>
                        <link>http://forum.genoqs.net/community/dev-den/octopus-only-v6-beta/paged/2#post-267</link>
                        <pubDate>Wed, 28 Dec 2022 13:19:04 +0000</pubDate>
                        <description><![CDATA[Hi there.
First of all, thanks for all the hard work on the OS, it&#039;s really appreciated now the Octopus is my go to musical gadget these days. Secondly, I must be a bit stupid because I ...]]></description>
                        <content:encoded><![CDATA[<p>Hi there.</p>
<p>First of all, thanks for all the hard work on the OS, it's really appreciated now the Octopus is my go to musical gadget these days. Secondly, I must be a bit stupid because I went through the update procedure and now when I start up while holding down 'esc' I see 6 red lights around the outer circle so I'm assuming this means OS6, the update procedure went as described in the pdf. However looking through the pdf titled 'Octopus Release Notes &amp; User Guide v6.0' I can't seem to access any of the features described, for example at the bottom of page 6 'Misc. Capabilities' clicking the tempo button on mine changes the progress circle from red to green rather than halving the tempo. I haven't tried all features but quite a few and I can't get any to match the manual.</p>
<p>Thanks.</p>]]></content:encoded>
                        <guid isPermaLink="true">http://forum.genoqs.net/community/dev-den/octopus-only-v6-beta/paged/2#post-267</guid>
                        <link>http://forum.genoqs.net/community/dev-den/octopus-only-v6-beta#post-259</link>
                        <pubDate>Tue, 07 Jun 2022 19:32:51 +0000</pubDate>
                        <description><![CDATA[i was thinking this was going to be the workaround after i looked through the manual a few times.  thanks for the quick response. just unpacked the machine and put it on my desk. should be p...]]></description>
                        <content:encoded><![CDATA[<p>i was thinking this was going to be the workaround after i looked through the manual a few times.  thanks for the quick response. just unpacked the machine and put it on my desk. should be posting a photo into the appropriate thread in the coming days after i decide how to hook everything up. </p>
<p>so nice to have the octopus back in my system, it really is an inspiring tool and a thing of beauty. thank you so much @jean @eellis @wilson and anyone else i may be unaware of for keeping this thing growing all these years. </p>]]></content:encoded>
                        <category domain="http://forum.genoqs.net/community/dev-den">Dev Den</category>                        <dc:creator>companyofquail</dc:creator>
                        <guid isPermaLink="true">http://forum.genoqs.net/community/dev-den/octopus-only-v6-beta#post-259</guid>
                        <link>http://forum.genoqs.net/community/dev-den/octopus-only-v6-beta#post-258</link>
                        <pubDate>Tue, 07 Jun 2022 19:11:34 +0000</pubDate>
                        <description><![CDATA[@companyofquail
No, its not implemented on the any of the octopus OS&#039;s (AFAIK)...........
However, its easy to setup template pages with the Flow Factor values stored to the tracks (for yo...]]></description>
                        <content:encoded><![CDATA[<p>@companyofquail</p>
<p>No, its not implemented on the any of the octopus OS's (AFAIK)...........</p>
<p>However, its easy to setup template pages with the Flow Factor values stored to the tracks (for your chosen attr's) &amp; then copy/paste a "flow" track to the page you wish to apply them on.</p>
<p>You will find all the Flow Factor shape values on page 48 of the v5 Nemo user guide</p>
<p> </p>]]></content:encoded>
                        <category domain="http://forum.genoqs.net/community/dev-den">Dev Den</category>                        <dc:creator>Jean Blanc</dc:creator>
                        <guid isPermaLink="true">http://forum.genoqs.net/community/dev-den/octopus-only-v6-beta#post-258</guid>
                        <link>http://forum.genoqs.net/community/dev-den/octopus-only-v6-beta#post-257</link>
                        <pubDate>Tue, 07 Jun 2022 03:08:53 +0000</pubDate>
                        <description><![CDATA[do any of the alternative operating systems for the octopus have the modulation waveforms like the nemo does? 
i think i must have dreamed it but for some reason i remember an octopus front...]]></description>
                        <content:encoded><![CDATA[<p>do any of the alternative operating systems for the octopus have the modulation waveforms like the nemo does? </p>
<p>i think i must have dreamed it but for some reason i remember an octopus front panel with some tape or photoshopped waveform scribbling from the nemo on it.  that would have been around 2010 maybe? its been a hot minute.  i have had a nemo off and on for many years now.  i sold my octopus in 2012 and i have a new one arriving tomorrow, super excited! i actually bought one that was purchased NOS from analoguehaven in 2019, so pretty insane find!! </p>]]></content:encoded>
                        <guid isPermaLink="true">http://forum.genoqs.net/community/dev-den/octopus-only-v6-beta#post-257</guid>
